주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Backlight only, no image after screen replacement
I replaced the front screen digitizer assembly on an Verizon iPhone 4. All instructions followed as outlined. Upon trying to turn the iPhone on, I see the backlight but there is no image at all. I disassembled, and reassembled rechecking all connections, etc. same issue. I have tried to soft reset, hard reset. Does not resolve the issue. When I hook the iPhone up to my PC it is recognized without a problem. Still it continues to only light the backlight but no image is displayed. Is something not making contact or should I conclude a faulty screen/digitizer assembly? Or is there another suggestion for troubleshooting?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 1개
velopro, replace your new screen with the old broken one and see what you get. Let us know.
댓글 달기
답변 10개
가장 유용한 답변
Hello All,
First - thank you to those that followed up to my post here. I appreciate your time and expertise!
This is a follow-up/conclusion to my situation.
To recap - it was to be a routine front glass replacement on a CDMA iPhone 4 due to a cracked digitizer screen glass. I tend to order the complete assembly to make is easy to turn around the repair, which it what I did. After the new digitizer assembly was installed and the unit was reassembled the result was a blank screen with only a backlight coming on, just a blank screen, no image. I went back and rechecked everything by disassembling and reassembling again, paying attention to all details. Same result - blank screen with only the backlight coming on. I plugged the unit into a PC and it was recognized, etc. No issue there.
To wrap-up here - I decided to reorder the digitizer assembly thinking it was received defective as there was no indication of a torn cable or other damage to the digitizer assembly.
Upon receiving the replacement digitizer assembly (from a different source than the previous one), I redid the repair and viola! all was resolved.
I would have tried the original assemble as well, but I needed to get the iPhone back to the owner, so in just ordered another part and hoped for the best. I will now return the other digitizer to the seller for a credit.
I did note some missing details from the instruction that involve a small clear plastic piece that is "fused" to the inside of the front digitizer panel and fits around the front camera - perhaps some means of securing the camera?? Also, my original source of the digitizer panel did not have kapton tape in places on the digitizer cables or the mesh on the front speaker port, both of which needed to be transferred from the original digitizer panel. These can complicate the repair if not observed and taken care of.
Any questions, do not hesitate to contact me.
Best regards,
Mike
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
hiya im havving problems with my phone basically it fell out of my pocket and landed on its back now when i try to use the phone its like lit up but no pictures or anything on the phone at all its just like a blue screen ? help me pleas
댓글 달기
Hi all,
I have a similar problem - I've replaced my screen & digitiser and only the backlight is working, no picture. It makes the camera sound when I do a screenshot so I know the device itself is on.
The old screen was still working, but the glass was smashed hence the repair. As per online advice, I reconnected the old screen, and now I have the same trouble - the backlight is working but there is no image.
I figure this indicates I have done something to the inside. All the connectors seem to be connected properly, as I rechecked this during both assemblies.
My next step is to clean all the connectors with alcohol, and I will let you know if makes any difference, but my question is: is anybody able to please let me know the purpose of each of the two screen connectors? I'd like to know which one I need to pay particular attention to.
Thank you
Update
Hi guys
Here is an update:
Cleaning the connectors with isopropyl alcohol didn't help, so I figured it wasn't a case of the connectors being dirty.
I took it to a professional fixer and now it works perfectly. He said I had most likely accidentally damaged the LCD ribbons on both screens (or the one I received was faulty and I had damaged the original while removing). In any case, the message was that the ribbons are super, super sensitive. Super.
Based on this info, if you're going to proceed with the fix I recommend making sure your parts are from a quality seller, are sent in rigid packaging, and you are extremely careful with the ribbons when feeding through. If your old screen still shows an image, take the same care in removal as you do in assembly (so you have something to test against).
Though there is of course definite value in taking your phone to a pro, I'm disappointed I didn't get to see what was done to it (or get the satisfaction of a successful repair). Also I have to take his word that it was the ribbons and not some trade-secret extra twist to a screw or something.
The pro expressed criticism of internet tutorials but I didn't ask why. Perhaps it is that they don't provide sufficient, emphasised warning for dangers like these..(?)
If the occasion arises in the future I would definitely attempt another fix with this knowledge. I hope this is helpful in any amount and am interested to know how others resolve the problem themselves.
Cheers
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hey Lucia,
I had the same problem replacing the screen on my iPhone 4s. Did you resolve yours?
First attached new screen - tested.. and saw nothing.. but the phone could receive calls, so I assume it was working fine (other than the screen of course - it was blank, not even a backlight.)
Reinstalled previous broken screen and now backlight works but no image.
I did have a fully functioning iPhone (with cracked screen) before trying the replacement.
- My only plan is to try another screen tomorrow.
thanks
댓글 달기
I don't buy the "fragile cable" story. I've got the same problem (backlight and sound only). I've tried the power on, home button, disconnecting the battery, etc... I replace screens for friends and family all the time. I had the opportunity to test the digitizer assembly on a different phone and it worked perfectly. The issue clearly with the phone. I hope someone figures this out!
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
James York - I realize this is an old thread, but I am only seeing it now, so I thought I would add my two cents. I agree with you; the cables are not THAT fragile. I have changed countless screens, and this iphone 6 plus is the first time I have had this happen.
Hi. If the screen assembly is working on other phones then the lcd connector from mainboard must be damaged :)
댓글 달기
Ok guys I had the same problem with a hot pink after replacing a new lcd on a 4s phone.The phone will not function at all no backlight at all.So I decide to try other just encase still the same result..The screens faulted out my 4s main board,so I decide to disconnect everything and leave it out for a few minutes so I can flush all the power form the main board.As I tried the second screen it work,but as I notice that there were more oil residue on the gold connector pins which connect to the main board.This maybe be the cause or the bad screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try holding both buttons down until the apple shows up. The phone will hard reload, but keep your buttons held clear through it until the apple shows up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try holding down the power button and the home button and it will work
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Update: Problem solved. After consulting a repair tech, he informed me that the part of the cable closest to the screen is very fragile. He continued to add that there's a piece of "glass" or similar inside the cable and it's likely that when I was feeding the cables through the phone body to set the screen in that I may have bent that part of the cable too far thus damaging the connection. (there was no obvious way too see that any damage occurred) This actually made a lot of sense though - cause when I tried reinstalling my previous cracked screen I ended up with the same issue. Which led me to believe that I also bent that cable too far l when installing the screen. (And I was trying to be so careful.. just didn't realize that cable was soooo fragile!)
I got a new screen and was extra careful not to move that cable too much at the base. New screen worked great. Live and Learn.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Once you did everything correctly, and only get the backlight when you power on, hold the power and home button at the same time, This will force the system to detect the new screen and start to output video to it. Hold the buttons until the apple logo appears. Make sure you do this before ordering a new screen. This will work 99.9% of the time once nothing was damaged during the repair....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey, so just to add my two cents, I had the exact same problem as all of you. I don't know exactly what I did to fix it, but it seemed dead, hooked it up to the old display and i got backlight and sound, then i attached it to the new one and i got backlight and sound. Tried doing home + power button and nothing, went back and hooked up the old display, this time the lcd worked and displayed the apple logo (probably from me holding power+home), I switched it to the new display and it booted up normally and made me reauthorize the phone. Maybe i tricked it into displaying on the new lcd?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Is it possible that the replacement screen was for an iPhone 4 and the 4s?. I have the problem also. When I test the screen before installation it worked. (I tested it on the 4s) once installed I also have a black screen but I can hear the phone.
Also I noticed on the replacement screen that the connectors didn't have the black cusihion tape attached.
댓글 달기
4/4S isn't really an issue. It's the bracket assembly, that's the real difference for those. I just now, after many many i4/i4S repairs, got this backlight only issue. Didn't get a chance to try it, without an extra battery, the current one had no charge. But advised the customer to try the power + home button thing
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
velopro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 36
전체 시간: 78,091
