주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 설계한 M1 Pro 및 M1 Max SoC를 탑재하고 올해 10월에 출시된 16-인치 MacBook Pro에 대한 수리 안내서 및 분해 정보입니다. 모델 A2485.
MacBook Pro - RAM usage while idle
Hi everyone,
I recently noticed that my MacBook is using around 6.5GB of RAM while idle, with no heavy applications running in the background. I'm currently running macOS Sonoma.
Is this normal, or could there be a memory leak or background processes consuming more RAM than expected? I'd appreciate any insights or suggestions on how to optimize RAM usage if needed.
Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Post a screenshot of the Activity Monitor, you can find it in the utilities folder.
How much memory does your system have? Typical idle usage of ram is normally anywhere from 20% to 30%.
@livfe I just added a screenshot. This device has also a fresh install.
@jmehnert 16GB of RAM.
댓글 달기
답변 1개
RAM usage is always tricky! To gain performance the system setup a cache area where the most active data is held (Apps and your work).
So if we turn this into a driving exercise between your car and mine going down the highway it’s likely one will use more fuel than the other. That also holds true with RAM! As you may setup a few more start items or even run a few Apps (even closing them) but the persistence of the cache is still present.
What you want to monitor is memory leaks where a given process keeps consuming RAM and not release it until to restart the system. Leverage Activity Monitor to review things over a period of time.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Uas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 29
전체 시간: 281
