주요 콘텐츠로 건너뛰기
Infinix Note 12 Specifications 2023 Model It was released on 2022, October 06. It has 6.7 inch, AMOLED, a resolution of 1080 x 2400 pixels screen. It uses MediaTek MT8781 Helio G99 (6nm) chipset, Octa-core (2×2.2 GHz Cortex-A76 & 6×2.0 GHz Cortex-A55) CPU, Mali-G57 MC2 GPU.
Why is it not charging at all?
i got the display changed recently due to it getting cracked in a road accident and completely blacking out. i went to do the customer care but the fixing price was more than 7k while my phone itself is 19k. i instead went to a trustee repair shop of my city and got the display changed for 3.2k and later on got the charging port changed too cause my phone wasn't charging. now it's not charging again and i can't use it at all.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
I put power cable butt not accept the charger
댓글 달기
답변 1개
가장 유용한 답변
@sreyoshiroshni I would replace the battery and the charging port again. Also, check the ribbon cable that connects the charging board to the main board. Those do come loose and even tear etc. If none of that works, the issue will be on your mainboard. Possibly damaged charging IC etc.
I would consider saving some money and to repair/open this phone by yourself. It is not that complicated. Check videos like this Replacing those parts is also straight forward.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Sreyoshi Roshni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 38
전체 시간: 482
