주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
질문 마감됨
Touchscreen not responding
I recently had the screen replaced on my phone after it shattered. I dropped it again and the screen came off in one piece. I put it back on and the home button is responding but the touch screen is not. Is it possible to fix on my own?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Try removing the display and check if there is Amy damage on the connector or cable attaching it to the phone.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
sarah langley, sure you can . Here is the guide iPhone 3G Front Panel Assembly Replacement and take a look at it. Verify that all cables are still attached and in good working order. If those are okay, I would suggest to change the front panel. I personally prefer the whole assembly, since it does work easier and quicker. hope this helps, good luck. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Totally off topic but today I found the cheapest iphone display assembly's (4 and 4S) The company (centrix) I have ordered from once before, they were good ad I received the item but it was a couple years ago
http://www.centrix-intl.com/details.asp?...
댓글 달기
About your last post, for some reason I cannot post comments, it doesn't allow me to. I had this problem after I tried fixing the home button. I actually tried doing everything here, and it turned out that the connector pad was broken. Had to take it to Apple store to be re-soldered.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did this a couple of times. I opened up the phone, closed it, and after 3 times of repeating this, the screen was half responsive, and half was not. I opened it up again, and it turned out that connector 2 was slightly loose, thanks for the answers.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 391
