주요 콘텐츠로 건너뛰기
Repair guides and support for televisions manufactured by Sony.
20 질문 전체 보기
Sony Bravia KDL 40BX240 blinks 3 time
When I turn on the Sony logo appears then it's turns off and blinks 3 times.
Why is this happening?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@tumelokgatitsoe not sure if you are talking about a BX240 or a BX420 but commonly for your TV the 3X Blink is listed as an DC Regulator/Audio Error. The REG 5V and D3.3V source originating on the main board is monitored for low-voltage conditions by the CPU. A failure causing a 3X shutdown would require replacing the main board
Verify your exact model number for us. Of course, if you can, remove the back cover after you unplug your TV. Then take some good pictures of your circuit boards. Post those with your Question. That way we can see what you see and hopefully help you further with this repair.
Here is the guide for that 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tumelo Kgatitsoe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 8
