My “w” key is not responding well.
So I’ve been using it for 3 years, now when I press lightly the w-key it won’t respond even to the bottom, but it will respond if I tap it with some force, so I assume it’s a switch problem, and I’m thinking of replacing it. But don’t know how or where to do this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Logitech G915 TKL Keyswitch Replacement
The individual switches may have dust/debris inside them, which is preventing the switch from registering a key press. The switch for W may require replacing. Either way requires you to completely disassemble the kb, which isn't fun, please take your time and clear a good amount of table space before you begin.
The good news is, these are simple to replace. The difficulty is the tedious disassembly/reassembly process.
댓글 달기
