주요 콘텐츠로 건너뛰기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
147 질문 전체 보기
What is the type of SSD in the MacBook Air (A1370)?
I would like to know the exact type of SSD in the MacBook Air Late 2010 Model. Does it use mini pci-e or msata?
Extra question: Does anyone know of the cheapest solution the read the data from the SSD by using normal desktop? (i.e. where to buy the adapter needed for this?)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 1개
선택된 답변
I thought the A1370 was the 11" and A1369 the 13"? Anyway the SSD drive uses a custom Apple mSATA connector.
http://www.everymac.com/systems/apple/ma...
If you want to connect the drive externally you could use something like this:
http://eshop.macsales.com/item/OWC/SSDAP...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
i got a miniSata adapter and it didnt line up at all, neither the width nor the position of the notch. anybody know whats going on? is it proprietary or not?
really dont want to get a special board just to read the data of the ssd.
@kugelzucker - You need the custom Apple mSATA blade SSD. An M.2 SSD won't work in your system.
댓글 달기
귀하의 답변을 추가하세요
Fadhil Ghazali 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 38
전체 시간: 20,645
