주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 일본, 2015년 9월 북미에 출시된 Nintendo의 첫 번째 주요 3DS 모델 변경 버전입니다. 2015년형 3DS는 개선된 3D 성능, C-스틱, 새로운 내부 amiibo 지원, 새로운 트리거 버튼 세트를 도입했습니다.
My 3DS won't turn on
I have had this console for at least 8 months, and it died on me. It was working fine too before it broke. No blue light would appear when I pressed the power button, and when I charge it, the orange light appears, then later dies after a few minutes. The weirdest thing about this error is when every once in a while, the New 3DS would boot on, and the battery would say that it's 3 bars full. Then after like 10 minutes, it shuts off automatically. What can I do to fix this issue? My DSi also died the same way, before the 3DS broke. I even changed the battery, and that still doesn't fix it. I want to deconstruct the 3DS, and see what's wrong, but i'm scared that i'll break the console. Is there a solution to fix this issue, or do I have to buy another one?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
There might be a faulty chip or component on the motherboard. Check if the old battery works on another 3DS. If it does, its a problem with the motherboard. If you're too scared to fix it, try get as much data off the 3DS onto an SD card and send it to someone to try repair it. If that doesn't work then you will need to get a new one. I wish you luck on fixing the 3DS.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Joshua Pangan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 258
