주요 콘텐츠로 건너뛰기
Repair information for the Asus ZenBook laptop series.
Asus ZenBook UM431DLaptop keeps getting stuck in automatic repair loop
A few months ago, my laptop started occasionally getting stuck in an automatic repair loop. I was usually able to get out of it using some combination of system restore, uninstalling updates, and just turning it off and letting it sit overnight. I have no idea which of those was the solution but it worked. Then about a month ago, it got stuck and nothing would work. I eventually used a boot USB to get into the hard drive and transfer my files off, then reinstalled Windows 10 via USB. I figured that would fix it as I thought the cause was an update that got half installed before my laptop died.
Last night, I left my laptop closed and plugged in (but not powered down) for a few hours and when I came back, it had brought up the automatic repair screen again and nothing so far has worked to get back into Windows. Seeing as I completely reinstalled Windows 10, I no longer think it it's just an issue with my copy of windows and instead either the windows updates themselves don't work with my laptop, or there's a hardware issue. I can get back in the same way I did before, but it's a pain in the ass. Ideally I'd like to prevent this from happening in the future. How would I go about this? Is it even worth it or would it be cheaper/easier to take it to a repair shop?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개
I was able to manually update the laptop so there are no updates pending, but when restarted it still does not want to boot into Windows properly. I think that narrows it down to a hardware issue. How do I figure out what the issue is so I can fix it?
@annaliesep
Please expand on what you mean by "....still does not want to boot into Windows properly."?
Does it boot fully into Windows safe mode OK?
@jayeff It will usually boot into safe mode if I select it in the startup repair menu, though the time I had to reinstall Windows it wouldn't boot into safe mode and eventually wouldn't even open the startup repair menu. Also in the time between my first post and yesterday's comment, I was able to boot into windows and use it with no problems for a couple weeks, keeping it in sleep mode when not using it. The only other issue I've noticed is sometimes the headphone jack stops working, but if I can get the computer to restart it will fix that.
Hey there @annaliesep ,
I know my answer is not going to be very helpful but I HAD to comment: I have been having for quite some time the EXACT SAME issue with my laptop, which is the EXACT SAME model as yours... Could this point to a broader issue of compatibility between Windows and this laptop model? Or maybe a generic hardware issue with this line of models? Hard to say... In any case, the only small difference with you is that I think I had yet to not be able to boot in Safe Mode.
Did you find by chance a solution to the issue?
Good luck!
@yugoboss No, unfortunately I don't have an actual solution. One thing I did do was realize Windows Update kept trying and failing to install the same update, which was why it kept restarting and getting stuck in automatic repair. I manually downloaded and installed the update and that at least stopped it from restarting regularly. I also paused updates for 35 days and kept the laptop in sleep mode when I wasn't using it so it wouldn't restart on its own. That 35 days is over and it still won't boot back into Windows after an automatic update, but they usually happen at night so I just shut it off and leave it overnight and it usually boots fine in the morning. So essentially, my "solution" is to minimize the number of restarts as much as possible.
The fact that both of us have the same issue with the same laptop does make it seem like it's either hardware failure or an inherent compatibility issue. Did you also start having issues around Nov 2024? We might be able to narrow down the update that did it.
댓글 1개 더보기
댓글 달기
답변 2개
선택된 해법
Hello again @annaliesep ,
Believe it or not, but since my last message, I think I finally managed to pinpoint the issue -- and solve it, thanks to a lot of googling and a little bit of luck!
At first I saw some people on the web saying that they managed to solve their issue by downgrading their BIOS version (I was using the latest version from the ASUS website, namely 306). It ended up not working for me, but it sort of helped leading me to the real cause.
In the end, it seems that this whole thing is related to the computer sound system: hardware issue, driver issue (like a bad install), its hard to say the exact cause, but it seems to be the culprit! Didn't you happen to have issues with your sound from time to time, like the sound stopping to work, or you plugging earphones but them not working, etc?
In any case, there's at least a very simple way to check if that the source of the issue: completely turn of your computer, and boot into the BIOS (to do so, press and hold the F2 key while the computer is off, and then press the power button while still holding F2). Once you're in the BIOS menu, go into "Advanced Mode" (by pressing F7), then use the left and right arrow keys to reach the "Security" Tab. Then, use the up and down arrow keys to enter into the "I/O Interface Security" option, and while in there change the settings of "HD Audio interface" from "Unlock" to "Lock": this will (temporarily) disable your laptop sound entirely. Now go to the "Save & Exit" tab and... save and exit :-)
Try to then boot the computer and see if this solves the overall booting issue for you; if it does, we can move on to a more permanent fix -- where you still have your sound enabled!
Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Sorry for the delay, I've been pretty busy with work and haven't been using my laptop much. I tried what you described and it booted right into Windows with no problems. What's the next step?
He never responded, but I figured it out myself. First, go to the ASUS support page for the laptop below, scroll down to "Audio", and download the newest Realtek driver:
https://www.asus.com/supportonly/um431da...
Find it in your downloads and double click to run the installer. Then, restart the computer and boot into the BIOS. Follow the directions above to change the HD Audio Interface back to unlocked. Save and exit the BIOS. Windows should boot normally now!
Basically all that's causing this is that Windows sees your audio drivers are from 2020 and tries to update them to something newer. Except there aren't any newer drivers compatible with your laptop, so it's erroneously finding some other Realtek driver in their database and installing it instead. When you try to boot, Windows tries to communicate with the audio chip with the wrong drivers, can't do it, and gets stuck trying over and over to do so, preventing Windows from loading.
댓글 달기
@annaliesep
Just some things that I'd check:
If it doesn't boot at all, i.e. starts but doesn't start to load Windows check if you can get into BIOS OK and then see if the SSD that the OS is installed on, is being shown as detected or not in the BIOS menus.
Booting OK in safe mode but not in normal mode usually indicates a driver problem. Since you've updated all of them that rules that out.
If it boots into Windows normal mode OK try turning off fast startup (should be the same in your laptop) and check if it consistently works OK now
If you can boot in Windows normal mode OK try running an sfc /scannow command and also all the DISM check health options to make sure that the installation is OK
As a final check to try and isolate where it might be, try running a "live" Linux OS e.g. Ubuntu Lite etc from a bootable USB flashdrive and check if it boots into the OS and works OK. You don't have to install it, just run it. (There's an option to install or just test when you first start it).
If Linux works OK then there's a problem with Windows and the laptop. if it also has problems then it's hardware.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It starts to boot Windows but gets to a loading screen with the Asus logo and the spinning dots and won't load further. The BIOS loads fine and the SSD is visible in the boot menu.
Only sometimes will it boot into safe mode. This morning it got stuck on that loading screen (it tried to run a new update and got stuck when it tried to reboot) and after I tried a system restore which did nothing, I tried safe mode and that also wouldn't boot. But turning it off and back on got me back to normal Windows.
I shut off fast startup a few days ago but it clearly didn't fix it.
I just ran those commands and I'll see if it helps, but I've done that several times trying to get back into my system before and it didn't seem to fix it either.
I used Hiram's Boot CD (actually a USB) to get my files off of it before and it loaded fine despite being Windows 11 based. All of the system-checking programs on it also didn't find any hardware problems. I'll try live Linux once finals week is over and I have more time.
댓글 달기
답변을 추가하세요
Annaliese P 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 56
전체 시간: 416
