주요 콘텐츠로 건너뛰기
Repair guides and support for phones manufactured by Oppo Electronics Corp.
Oppo reno 2f wifi and bluetooth problem
Wifi and bluetooth not connecting. Anyone tell me what happened.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @pankajderkar
Try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it detects, connects and maintains a stable connection.
If it does then it may be a loose/faulty antenna in the phone.
Here's an image from this teardown video showing the antenna connections.
If the antenna is the problem then the same antenna is used for BT as well, that is why you are having problems with both.
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
pankaj derkar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 87
