How do I reinstall display adapter
i accidently uninstalled my display adapter. how do i reinstall it windows boots up but after it does my screen goes blank
좋은 질문 입니까?
좋은 질문 입니까?
Alright, so this is what I've found.
You should be able to restore your deleted display adapter through the Acer eRecovery Management system.
You can access this system during the boot up process, which will bypass the need for the display adapter to load, by pressing the hot key (Alt + F10) which will start the Acer eRecovery Management system.
Reloading your display adapters from this system is your best option.
Let me know how it goes.
해당 답변은 도움이 되었습니까?
You should be able to go into Safe Mode. So do it from there. After going to Safe Mode, go to Computer Management and Device Manager to update the display driver.
Ask again, if you have any problems.
Max
해당 답변은 도움이 되었습니까?
hope this can hep m too. I just reformatted my acer aspire one notebook, after restarting.. the laptop stills power on but no display comes up. Thanks in advance buddy, i'll try your suggestions. I have tried some other tricks from other sites but did not worked.
I will inform you soon once I solved my same issue. Thank you!
I'm ronie cambronero from Philippines +639196029417. A one year as computer technician.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 7
30일 전: 12
전체 시간: 1,272
댓글 1개
How'd it go? Any luck?
Nicholas 의
