주요 콘텐츠로 건너뛰기
Msi pro b760m-a wifi ddr4 how to replace CMOS battery
I want to replace battery and wnat to buy which one battery
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @kingsam
Here's the user manual.
Go to p.39 to see how to remove/replace the cmos battery.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
But there is an iron plate stuck
@kingsam
Post an image of the motherboard showing where the cmos battery is and the plate.
Here's how to do this in ifixit 기존 질문에 이미지 추가하기
Ok i upload the image tq
@kingsam
That is a heatsink over the IO (Input/Output) IC chip
It's either held on by clips (I can't see any in the image) or it is screwed onto the motherboard
If the motherboard is still in the case you may have to remove it from the case and then unscrew the heatsink from the underside of the board.
Usually the cmos battery model or part number is on the battery itself.
use that information to find suppliers
댓글 달기
가장 유용한 답변
For those finding the CMOS battery on b760m-a, it is right under your display card not inside the heatsink! I cut my finger when trying to reach under the heatsink!!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
king sam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 44
지난 30일: 201
전체 시간: 1,829
