Refrigerator cycling on and off every 5 to 10 mins
I'm looking for some troubleshooting advice for my Whirlpool refrigerator (Model: GD5RHAXNQ00). Here's a breakdown of the issues and what I've tried so far:
Initial Symptoms:
- A while back, I noticed the compressor was knocking against the metal inside.
- Around the same time, the fridge seemed to be running much more constantly than usual.
- My power bill showed a noticeable spike from the kitchen.
- I timed the fridge cycle and found it was running for 6-10 minutes, shutting off for 6-10 minutes, and then repeating this cycle continuously (short cycling).
- Despite the running issues, the fridge was (and still is) doing a fine job keeping things cool.
Initial Troubleshooting Steps:
- I managed to stabilize the compressor to stop the knocking.
- While checking things, I cleaned the condenser coils.
- I verified that the condenser fan was running correctly when the compressor was on.
Attempted Fixes & New Problems:
- Thermistor Replacement: I suspected the thermistor (this model only has one). After replacing it and reinstalling the temperature control unit, the fridge would no longer start running at all (it was clearly getting power, just not kicking on).
- Reverting Thermistor: I put the original thermistor back in, but the fridge still wouldn't start.
- Temperature Control Unit Replacement: Believing the control unit might have been the issue all along, I ordered a replacement unit from eBay and installed it.
- Current Status: The fridge now runs with the replacement control unit, BUT the original short cycling issue (6-10 mins on, 6-10 mins off) persists.
Additional Information:
- Ice Maker Issue: Around the time the initial problems started, I was also having trouble with the ice maker (cubes were getting stuck and water was constantly running, freezing down the side of the fridge. It also got the infrared control unit wet and that stop functioning. I removed both and wrapped off the cables they were attached to.
- New Control Unit Glitch: With the "new" (eBay) temperature control unit installed, it generally works, but after several hours, I'll find the two LED number displays blinking. This stops if I unplug the fridge and plug it back in. I've removed the unit and re-checked that all cable connections are snug.
My Question:
Given that I've replaced the temperature control unit and the short cycling issue still persists, what should my next steps be? Thanks in advance for any suggestions!
좋은 질문입니까?
