주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameCube는 Nintendo의 네 번째 가정용 게임기입니다. 수리는 간단하며 일반적인 수리 도구만 있으면 됩니다.
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
댓글 달기
답변 1개
선택된 해법
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
Glad that a new memory card did work! Have a great day :)!
댓글 달기
답변을 추가하세요
Nirby 74 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 20
전체 시간: 225
