주요 콘텐츠로 건너뛰기
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 질문 전체 보기
Which parts are required to complete a screen replacement
I have replaced the digitizer on a few iPad 2nd gens. I typically replace the middle frame bezel every time I replace the digitizer. I haven't been able to find replacement middle frame bezels for the new iPad. I was wondering if the iPad 2 bezel would fit, since the old one typically gets some minor damage during removal of the digitizer. Also, is the adhesive similar between the generations?
-Thanks,
jwesleym
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
I just did an iPad 3 Screen replacement,
For the most part, the replacement is about the same - and most of the adhesive is the same too (there are a couple of bits different, but nothing that should affect anything). The part I ordered came with the plastic bezel, I do not know how similar it is to the iPad 2 as I have never replaced the bezel with the screen in the iPad 2.
-David
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
How much does the screen cost?
댓글 달기
I would also recommend foam tape gasket around the LCD. It gets torn when opened. Dust will enter the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I use the old bezel too (only if it is in Good condition).
And you, you too or not?
Thanks, Mauro Ju Macniaco
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jwesleym 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 3,108
