주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
hard drive slow and with strange behavior
I think my hard drive is failing because after a series of tests with Disk Utily and Apple Hardware Utility, I got errors. For example, Apple Hardware Utility test has detected an error 4HDD/11/4000000 SATA(0,0). My Mac is slow and with strange behaviour.
I think I will replace the drive, but some people said that perhaps the HD fan is with problem. But when I run iStat Pro it shows the HD fan running at 1200 rpm.
How could I be certain that the problem is only with the hard drive and not the fan?
I found the procedure to replace the fan in this site, but you don't sell this part. In case I need, where can I find the HDD fan?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
The part number for the 2.4 GHz hard drive fan for a mid 2007 iMac is 922-8202. Just Google that number. If it doesn't cost to much more, go with a new fan rather than a used part.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
sergio barrozo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,368
