주요 콘텐츠로 건너뛰기
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
trying to solve a code 302 in a 2011 escape
I’m trying to resolve an intermittent misfire in cylinder 2.
I first changed the spark plugs and found oil around the plug. I changed the valve cover gasket. No success.
Next, I checked the coil. It was OK. No success.
Next, I cleaned the mass air flow sensor and changed the air filter. I also cleaned the throttle body and put a bottle of Red Line engine cleaner on the tank. No success.
Next, I did a compression check. 3 cylinders were the range of 150 the number 2 came up around 120.
Next, I cleaned the fuel injector. No success.
Any suggestions? ThanksHow do I submit a question?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
This question was migrated from https://meta.ifixit.com/Answers.
댓글 달기
답변 1개
가장 유용한 답변
@davesharkey I assume the error code was actually a P0302. Besides all of the things you've already done, check for sticking valves or failed piston rings. Those things would also explain the lower compression. Do a leak-down test next and see what that tells you.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanksoldturkey03, I’ll try these.
댓글 달기
답변을 추가하세요
Dave Sharkey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 66
