주요 콘텐츠로 건너뛰기
이 Nintendo DS Lite는 2006년에 Nintendo DS의 후속작으로 출시되었습니다. 이 기기의 내부에 진입하는 방법은 간단하여 손쉽게 수리할 수 있습니다.
turn on and then immediately off
My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 24
댓글 6개
trun on problams
plz talk to me
Ha (that happiness to me to)I don't know how to fix it
How to fix a DS lite that turns on and instantly off
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
댓글 1개 더보기
댓글 달기
답변 8개
가장 유용한 답변
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
Nintendo DS Lite
Though there is another apparent option which centers around possible hinge damage. Does it appear that there was any damage to the hinge in the fall?
If so you may just need to replace the casing and one of the screens to rectify the issue. In which case the above guides would also be useful.
Also, if it turns out you need replacement parts, this is a good spot to start looking.
이 답변이 도움이 되었나요?
점수 13
댓글 6개:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
That´s the answer I was looking for. tnks
it work on my ds
turn on problams
Lol, it's been a long time since literally "jiggling the cables" was a solution. Disconnect, and reconnect, the 3 ribbon cables, works like a charm.
댓글 1개 더보기
댓글 달기
one of the connectors is not connected anymore
이 답변이 도움이 되었나요?
점수 1
댓글 달기
hold the power switch on a maximum 1 hour and keep the ds game inserted.
if your daughter wants swap the ds game your daughter will need a gba game
이 답변이 도움이 되었나요?
점수 0
댓글 달기
maybe it was just from the fall
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi, if you’ve got no flash screen, consider to try my fix here.
The DS won't turn on. Green light flashes for a second.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The problem might be in the battery compartment
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i will try shaking mine and see if that works, since i might just get a new one, if we can't fix it
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i did not work :'(
댓글 달기
My aunt’s DS lite’s power switch is broken. I would slide it to the on side but then it just moves to the off side. Is that supposed to happen?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
khan786 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 94
지난 30일: 431
전체 시간: 94,084
