주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
MacBook screen flickering and after while it freezes with blue screen
Hello i recently bought used macbook from internet
Works very find but when i use macbook sometimes screen flicker
i dont know what cause this but i didnt care about it(it happens 1~2times while using 4-5h)
but suddenly it stopped with blue screen or pink brown or some other color
It was working fine until last week so seller is innocent (at least i think so)
I tried nvram reset/reinstall mac os/smc reset/auto graphic change? Disabled
Is there some way to fix it please help me
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
There are two versions of this series one with just the iGPU (Intel chip graphics engine) and the other with a AMD GPU chip. Do you know which you have? Here's a listing of this series:
If you take the bottom cover off you can see the difference in the heat sink as it will either only have one chip pad or two. Follow this guide to get it off MacBook Pro 15" Retina Display Late 2015 하단 케이스 교체
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I think it is dgpu model
today it restart after freeze with white screen and it says macbook restart because of crash
I tried apple diagnostics but no error detected
@suck24877 Can you take the bottom cover off and take a couple of good photo's so we can see, posting them here.
If you got a crash report that would be helpful when diagnostics doesn't pop an error. From the sounds of it it sounds like the GPU maybe failing or just overheating. Are you up to cleaning the logic board and re-pasting the thermal paste on both the CPU and GPU if present.
댓글 달기
@suck24877 Here is a video on how to do the thermal paste on the CPU/GPU. just in case https://www.youtube.com/watch?v=7912tmng...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Suck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 16
전체 시간: 88
