주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
games crash after 1 hour of use
when i use my ps4 for an hour the game crashes pls help its ugent
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 8개:
Hi!
Do you have an error code?
Does the PS4 make a lot of noise?
Does it happen with disc games and downloaded games?
Could be the HDD, could also be the heat..
the first time it happened it was due to an update installing then it lost power
@dan0 CE-34878-0 thats the code i get aka downloaded
Okay, that always a bad thing. I would try to check if it's updated for sure. If yes, you can reinstall the software completely and see if that works. If not, try replacing the HDD for a new (or known working) one and install the software on it.
it has been replaced because the hdd failed it started making those clicking sounds
댓글 3개 더보기
댓글 달기
답변 1개
The error code you provided, CE-34878-0, doesn't pinpoint any specific problem. It's an error code that simply indicates a crash. You may have to try troubleshooting.
PlayStation recommends doing the following. Try these and see if the problem persists:
Make sure the PS4 is updated
Unplug your PS4 camera and deactivate face recognition, if applicable.
Reinstall the original HDD, if previously replaced
Which update was installing? An update to an app in your library, or a software update?
The update of the game could have a bug, if it only occurs in one game. You could report it to the developers, and they could fix it.
Based on your completed guides, it seems you have recently replaced the HDD. Try reinstalling the original, as PlayStation suggests.
Source
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
the old one broke i heard clicks from the hdd
Then you need to replace it to get it fixed!
Guide: PlayStation 4 Hard Drive Replacement
@dan0 replacing it is what caused all of this.
Ah, I thought an update caused this. @ryanklothk25632, did you actually already replaced the harddisk for a new one, or working one? If yes, were you able to install the software completely?
Yes I did and I still have the reinstall usb
댓글 1개 더보기
댓글 달기
답변을 추가하세요
ryan kloth køie greve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 137
