주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
Why is my screen flickering and backlight completely shutting off?
This happens periodically, I'm sure it has something to do with the display cables.
Does anyone have an idea of how long or where I could find the cables to replace and which ones will actually fix this?
I've tried doing a display update, which fixed it for about a day.
It doesn't happen all the time, but when it does it is very annoying.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 3개
선택된 해법
After working on laptops for a while, in my experience, 95% of the time it will be the inverter and 5% it is the LCD itself, both fairly simple to replace.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
It's probably not the cables. My guess is your display inverter needs to be replaced.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
I have this same problem when my brightness is set really low (1-3 bars). I brought my laptop to the Apple store to replace the inverter, but that didn't fix the flickering. At least in my case, I think it could be a problem with the display.
댓글 달기
If it's flickering, it is quite possible the inverter cable has just come lose and just needs to be reseated. When the backlight goes off, try tapping your top case near the top left and also the clutch cover around the left side. If this resolves it, then the cable may just need to be reseated.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
davidaase 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 17,593
