주요 콘텐츠로 건너뛰기
Model missing from the list? (7VK32EA/15-DR0018NA)
Hello,
My laptop model is missing form the wiki list in here.
Is this an oversight or I am in the wrong section here?
HP ENVY x360 - 15-dr0018na / 7VK32EA>
Can I use the maintenance paper found in other thread for this laptop? Maintenance and Service Guide HP ENVY x360 Convertible PC
Thanks in advance,
ADR
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @adr15393
Presumably whoever created the guide must have missed a few model variants.
According to the HP ENVY x360 - 15-dr0018na support page, the maintenance and service guide that you linked is the one to use for your particular model.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hello again sir,
I started my journey to change few hardware parts.
According to the manual I managed to some part numbers to user. However, when I get to keyboard (I understand the top frame is included) it has four variations. I'm a bit confused.
Options are:
With discrete memory
Without discrete memory
With Uma memory
Without Uma memory.
How to understand which goes to my laptop?
Thank you.
@adr15393
Looking at the specifications for your particular model, it has a discrete GPU i.e. an Nvidia GPU and also an Intel UHD 620 GPU which is integrated with the Intel CPU i.e. two GPUs allowing you to select which one you want to use for graphics handling.
Because the Nvidia GPU has its own memory it doesn't share the discrete memory with the Intel GPU.
So your model is the one with discrete memory.
If there was only the CPU and not also another separate GPU it would be classed as UMA.
Easiest way if you're going to replace the keyboard/top cover assembly is to look for the HP part number on the underside of the original assembly
댓글 달기
답변을 추가하세요
ADR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 69
