Not having any video output
I am currently in the process of rebuilding two computers after doing a teardown and refurbishment, on both systems so far I am getting no video output no matter which output I try, (HDMI, VGA, DVI Display port) one motherboard being a asus f2abs-m and the other also being a Asus board, both boards are still out of the case, I have all the necessary hardware installed, (Sata drive, RAM, CPU, etc) I am now at the stage where I am trying to boot the computer and I am not getting any video output, no matter which output I try, the monitor acts like it's gonna connect for a about 5 seconds and then nothing, I am having the same problem with both boards, I am fairly proficient at building systems and I am sure it's something really simple that I am over looking, any help would be appreciated
좋은 질문입니까?
댓글 3개
Hi!
Can you share the CPU models with us? Which CPU's did you used? Do you have a GPU installed, if yes can you share the model with us? Or are you trying to use the integrated graphics? Regarding the motherboard, could it be the: ASUS F2A85-M LE instead the F2ABS?
koppie007 의
I can do that, the one is the Asus F2A85-M and the other is the AsRock B450M/AC
Nicholas Keck 의
Do you plug cable into the motherboard? If yes you should plug it into GPU.
51515 의
