주요 콘텐츠로 건너뛰기
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
20 질문 전체 보기
A/V Cables not working properly
Last night on the ps3, I was playing mw2(2 thumbs up for infinity ward). While playing I had a graphic issue using my HD conpeont cables that i bought for my ps3.
I don't know if the a/v cables went bad or the ps3 died. How can I find out?
If it is the cables, what kind should I get?
And by the way i have Monster Game Conpeont cables for my Ps3 fat
p.s. i own a 2usb 80gb
(400$$)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 4개
unintelligible, again
I need help with this
thanks nat welch now i know how to ask this
right now im using SD cables i had from a ps2 that broke
댓글 달기
답변 2개
선택된 해법
You can also try a different set of cables including if you have it the stock AV cables that came with your system. Also try a different TV set or Monitor and see if that works.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Thanks so much Nat for the translation and spelling. Who says the older generation can't communicate with the younger? This type of machine fails so many times due to cheap cables and heavy use that I would never go the cheap route. Go to Radio Shack and get the best they have. If the PlayStation is bad you will always be able to use them with a newer machine. I prefer the "Monster" brand. http://www.monstercable.com/
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
As an audio technician, I respectfully disagree about Monster cables. In the sound industry, nearly everyone agrees that they are overpriced and not worth it.
thanks i have a jvc tv from may 2004 and i have monster cables
Josh, if you have a constructive comment, then you need to try to answer the question yourself. You offered no alternative, just criticism.
I'm sorry- I didn't mean it as criticism. I simply meant it as a way to save the chap some money if he needed new cables. I tried to convey that, but I guess I failed. I apologize.
Thanks. As an audiophile what cables do you recommend?
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,260
