주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
iPhone 8 not recognizing Charge. Suggestions?
Hi I am hoping this gets some attention before I send my phone away, im pretty sure i know whats broken but just want to check to see if there's anything else I could check first.
I was working on my iPhone 8 as it needed a new Battery as I was working on it I accidently broke the ribbon connector for the Taptic Engine, I finished installing the battery while i waited for a replacement engine and the phone worked fine. However While i was Taking it apart to replace the Taptic i forget to disconnect the battery in my haste and now the phone will not show battery Percentage or seemingly charge, it will eventually show a percentage after sitting on a wireless charger for a while but in that time it randomly turns on and off. all i have found googling is that I must have damaged the MOSFET's, they dont look damaged but they could be.
Sorry for the long Question hopefully it makes sense.
Does anyone else have suggestions on what else it could be before i send it away?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
댓글 달기
답변 1개
I'd recommend changing out the entire charging port flex cable.
You can find the part with or without the exact toolkit you need
HERE
iPhone 8 Charging Port flex cable Replacement
Replace a lightning connector assembly compatible with the iPhone 8. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-01163. 이미지
제품
iPhone 8 Lightning Connector Assembly
$49.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
que que 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 98
