주요 콘텐츠로 건너뛰기
Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
New apple watch not working - charging crack?
I everyone,
At Christmas, our employer gave gift and one of them was an apple watch 6. The employé who won it, kept it to give as a gift later.
Unfortunately, it's not working, it's now too late to return and apple was asking 400$ to send for repair. (Rip off), so at work they were like never mind.
I took it to see if I can repair and then give back as a gift for one of my employee if possible.
The watch doesn't turn on at all.
I let it on charge for over a day without success. Unfortunately, I don't have other cable to testthat component but I have wireless phone charger. May be?
I suspect the battery is dead but does that make sense?
I also see a tiny crack where the charging and sensors are. Could that be the issue?
What do you think? I am uploading a picture, it's difficult because of the reflection.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The crack is telling us the battery has failed as it swelled pushing out cracking the sensor plate. And as you are unable to charge the phone I think it's clear this phone will need both a backplate and battery.
I strongly recommend you review this Apple Watch Series 6 분해도 so you get an idea how far you'll be disassembling the watch to replace the backplate. Then follow this guide on replacing the battery Apple Watch Series 6 배터리 교체
I think you should find junker Apple Watch (any) so you get an idea what it will take and test your skills Between all of the parts you'll need it's close to $100 USD.
Apple Watch Series 6 이미지
안내서
난이도:
조정
Apple Watch Series 6 배터리 이미지
안내서
난이도:
조정
45 minutes - 2 hours
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you
So even if never used, the battery can have expanded and cracked the backplate?
How? Heat or manufacturing part?
Should I expect other issue then ?
Thank you again
@watever94153 - Sadly yes. The issue is the state of the battery when it was stored away. You want it half charged and fully turned off.
As far as encountering it again I can't answer that
댓글 달기
답변을 추가하세요
Watever 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 43
