GE GFW850SPNRS Washer Not Draining
Model Name: GFW850SPNRS
I have a less than 2 years old GE Washing Machine. The drain won't initiate.
- I've had this issue before in Year 1 and clearing the bottom drain filter fixed it.
- 2nd Occurrence, there were no signs of blockage on the drain filter so I suspected it was the drain pump. Upon disassembly of drain pump, I found the clump of hair and other objects which get past the drain filter and was found on the "L" corner of the small hose that connects to the drain pump to the drain hose. Clearing the hair fixed it.
- 3rd Occurrence, 1 year 6 months, it stopped draining again, this time, it's clear on the filter, disassembled the drain pump to inspect and see if there's hair trapped on the drain hose. Everything is clear. I tried replacing it with another drain pump but I can't even hear a hum sound when trying the service mode 12. I don't know though if I have a defective new drain pump or if it's the control board.
- The error codes are: 18 19 23 26 27 38 48
- I just ordered a digital multimeter to test the drain pumps.
Anything else I need to perform?
좋은 질문입니까?
