Ps4 ejecting disc by itself
Why is my ps4 keeps ejecting disc by itself?and wont insert any disc
좋은 질문입니까?
좋은 질문입니까?
Hi!
Most of the time caused by the disk drive it's mechanism!
It's recommended to replace the drive completely. Be aware to transfer the original disc drive PCB to the new drive!!! Otherwise it won't read any game...
Guide: PlayStation 4 Optical Drive Replacement - iFixit Repair Guide
You can buy the parts seperately, but it's not easy to find them...
Please let me know if you need anything else, or if you have any questions!
이 답변이 도움이 되었나요?
If you have a V1 or V2 PS4 with touch-sensitive power and eject buttons (unlike the physical press buttons on the V3), the issue is most likely due to a combination of heat and the metal spring making contact with the rubber front stand. The easiest way to diagnose this is to remove the bottom base plate and see if the PS4 starts behaving normally.
이 답변이 도움이 되었나요?
Hi! At that moment, the PS4 should give a "beep", like the ejecting beep. And should inject the disc sort off. But, it is possible if the internal speaker is broken!
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 92
