주요 콘텐츠로 건너뛰기
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
playstation 1 with no audio and video
hello, i have a playstation 1 fat, the model is SCPH-7501, when i turn it on there is a slight interference in the tv for a second but there is no audio and video, it has a working power supply, the AV cables are good since i tested them with another 2 consoles and they work fine and the tv also works fine with my other 2 playstation 1's, can someone help me find the issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 7개
Hi!
Could be many things...
How is the AV port? Still looking good? Can also be the CPU or a short on the board.
Do you have any soldering experience?
@dan0 the multi out AV port has rust on the top but the pins look fine, and i have a little bit of experience with soldering
Alright, should not be a issue. Can you share some pictures with us? Regarding the AV port but also regarding the motherboard? My feelings are telling that it's the motherboard... CPU or something...
here are some pictures of the multi out av port and the mother board[image|3728066][image|3728064][image|3728065][image|3728062][image|3728063]
Hi!
I cannot see the images unfortunately. Is it possible to check this guide?
기존 질문에 이미지 추가하기
Thanks!
댓글 2개 더보기
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Thanks for the pictures!
First of all, I would clean the AV port completely with isopropyl alcohol and see how that goes.
It is modded, you can try to unmod the PS1 and see how that goes!
If both failed, it's most likely GPU related... But before we jump to that, I would try the above.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
i cleaned the av port and still got no video and audio, the ps1 was modded so i unmodded it but i still got no video and audio, where do i get a new GPU chip?
Yeah, something on the motherboard did die... It's very hard to get those IC's. The only way is to get it from a broken/donor motherboard. Sorry..
@dan0 alright, i will keep the motherboard in case i need parts for my other 2 Playstation 1's, thanks for the advice :D
My pleasure! That’s probably the best thing to do now! Have a nice day and take care!
댓글 달기
답변을 추가하세요
tailsthefox2014 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 80
전체 시간: 312
