주요 콘텐츠로 건너뛰기
마더보드 및 CPU 수리 안내서 및 지원.
Upgrade a Toshiba Satellite C650D With a C855D Motherboard
I have a Toshiba Satellite C855D Motherboard and a person's needs his replace but his model is Toshiba Satellite C650D are these interchangeable with each other?
Thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@tj8799 this will only work if the physical layout of the motherboards are the same. Connectors and mounting points will have to be identical. Then you will need to check that the individual connectors are "wired" the same to ensure compatibility. I do not have the board views for these motherboards but I do have the schematics. Use those to check compatibility for the architecture of your boards. Toshiba Satellite C650DToshiba Satellite C850D C855D
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you will look at a c650D and image it next to a c855D and see if they look the same
Thank you again
댓글 달기
답변을 추가하세요
tj8799 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 36
