주요 콘텐츠로 건너뛰기
Self-priming automatic electric pumps with helical gears, produced by Marco.
Can UP3/E function on slow speed with SCS?
I have installed a Speed Control System together with my UP3/E pump. Normal speed, pump is working perfect. When I select slow speed, the pump is pumping slowly for a while until it stops completely and it will not pump again until I press reset button. LED is steady red as from the moment I select low speed. When pumping the red and blue led blinks alternatively. When I select the high speed again, the pump is working perfect again. My question: Does someone recognize what I wrote down? Is the SCS compatible with the UP3/E or is it maybe not?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @martijn24144
According to the user manual: "The electronic pressure sensor, through the use of a microprocessor, controls the pump’s speed to obtain the needed flow rate ......".
I assume that this would mean that if the flowrate is insufficient then the pump will be shut down.
There is a graph on p.14 showing the flowrate which may help.
You may have to adjust the SCS so that at low speed it still supplies sufficient power for the pump to provide the minimum flowrate
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you very much! This was indeed the solution of the problem👍🏻
댓글 달기
답변을 추가하세요
Martijn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 44
