주요 콘텐츠로 건너뛰기
The JBL PartyBox 300 is a large, powerful Bluetooth speaker that delivers rich sound with a selectable bass boost. It features an integrated light show with various modes that sync to the music. The built-in rechargeable battery provides up to 18 hours of playtime. The JBL PartyBox 300 became available for purchase in October of 2018.
The bottom speaker not working - sounds terrible and staticy
And i don’t know if it’s cause the bottom speaker don’t work but it’s sounds terrible and static
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@pupusa first do a visual check of your speaker. Check the speaker cone for any rips or tears. Yes, you can gently push the speaker cone inward and if you feel a scraping you may have a damaged speaker. The most reliable test would be to check for continuity and resistance of your speaker. Here is a good guide on how to check speakers and the wiring How to Test Speakers and Wires
If your speaker checks out okay, you need to check the amplifier circuitry of your PartyBox. For that use the SM that you can find under the Documents Tab on this JBL PartyBox 300 page. Pay particular attention to the capacitors in this circuit.
If you are unsure about those components, post some good pictures of the circuit board with your question. that way we can see what you and hopefully help you out further. 기존 질문에 이미지 추가하기
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Sony SS-CCP1 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You have to check out the resistance of the speaker, try to manual push the speaker part to check is it stuck in the magnet. If everything's ok with the speaker, check the speaker amplifier IC.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pupusa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 47
