주요 콘텐츠로 건너뛰기
Repair guides, user manuals and services for the Asus ROG Zephyrus G14 laptop. The Zephyrus G14 is a 14-inch Ryzen-powered gaming laptop, first released in mid-2020.
Help finding identifying edp connector to find replacement part
I bent a few pins on the connector by accident when repairing something else, cable seems fine. It’s a 40pin (J4502/LVDS) connector. Any tips on where to find/how to search for a replacement part?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@mathdragon the official description for the connector is LVDS WtoB CON 40P 0.5MM.S/T//ACES/50398-0407B-001. That means you are looking for an ACES 50398-0407B-001 (40-position, 0.5 mm pitch) connector. Check and see if ACES still makes/has them.
Otherwise you would need to try and find a "broken" motherboard and harvest the connector from that.
Before replacing it, I would try to bend those pins back. Some small hemostats or similar might get them straight enough to use your cable again. Remember, you can't make it worse since you are already contemplating of replacing the connector itself, which is a PITA to solder.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you so much! I think I broke one of the pins trying to bend it back unfortunately.
댓글 달기
답변을 추가하세요
Math Dragon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 79
