주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10세대 Apple iPad 수리 안내서, 분해 및 문제해결 정보를 제공합니다. Wi-Fi 및 셀룰러 모델로 출시되었으며, 64GB 또는 256GB 저장 용량을 갖추고 있습니다. 2022년 10월에 출시되었습니다. 모델 번호 A2696, A2757, A2777 또는 A3162로 식별할 수 있습니다.
My iPad won't charge
So my iPad won't charge. When I first bought it (used) it had some charging issues but after some time it worked fine. I sometimes had to turn the Cable because it didn't charge. But now it completely stopped charging. If I connect the charger it does nothing, if i turn it off and connect it, it boots automatically and a message pops up saying "Accessory connected" but it still wont charge. The Port is clean and I've tried many different Cables, including the original one.
About the "Accessory connected" Message, my iPad 7 keeps getting the same message but charges perfectly fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
From your description, it sounds like the charging port is starting to fail internally. The “Accessory connected” message usually points to the iPad detecting the cable but not making a solid power connection. Since you’ve already tried multiple cables and cleaned the port, the next step is checking the charging port itself—it may be loose, worn, or have damaged pins.
In many cases, replacing the charging port assembly fixes this completely. If not, it could be a charging IC issue on the logic board, but port replacement is the most common solution.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
flo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 276
