주요 콘텐츠로 건너뛰기
2023년 10월 15일 발표, 모델 번호 SM-A055M으로 식별됨
How to change my down board
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@eviplli are you referring to your charging board? If not, you will need to clarify what down board you are referring too.
댓글 달기
답변 1개
가장 유용한 답변
@eviplli just in case you are referring to the charging board :-)
Since iFixit does not yet have a specific guide for this, use something like this video to work on your phone. You do not need to remove the main board. Make sure that your issues are coming from the charging board. The A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Evipl Li 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 35
