주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
Top row of letters will not print, LCD appears to have a dead spot.
Has anyone ever had a problem like this, I just put a new blue mirror screen and back on a iphone 4s and now I'm have all types of problems, one of which is top row of letters will not display when I type them and another problem is that I can't select the sound function from settings unless I scroll up or down as if the LCD has a dead spot, all others can be selected. But when I'm able to select the sound function and try to select a sound I get nothing but a buzz sound from all the sound choices.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Either your digitizer is faulty (you will need to return your assembly for a replacement) or your mainboard connector is damaged or components around it. Some components around the digitizer connection can cause this to happen. Check your mainboard, especially around your digitizer connection. Your LCD Does not have a dead spot, its your Digitizer that does.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tofeva 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 536
