주요 콘텐츠로 건너뛰기
Apple이 설계한 M1 Pro 및 M1 Max SoC를 탑재하고 올해 10월에 출시된 14인치 MacBook Pro에 대한 수리 안내서 및 분해 정보입니다. 모델 A2442.
Power issues with both MagSafe and USB-C ports
I had a problem with my MacBook pro 2021. M1 chip and was only using it about a year when I was having problems where it wouldn't charge.
So I sent it to some guy on YouTube or company on YouTube in Virginia. They charged me $200 to tell me that I need to have parts replaced on the circuit board that will cost me over $1,000 or $600. And then I found the guy on eBay and he's been working on my laptop and said that there were about four capacitors that shorted out.
So I think that your problem's probably related to bad capacitors. It could be shorting out the rest of the board so it's best not to have it plugged up at all. And if you're looking to have somebody fix it, you probably will have to pay about $300 to $400 if you go with somebody off of eBay
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would say it's very rare to burn that many Capacitors! Often I see that when there is a lightning strike which zapped the logic board or the buildings ground is hot and/or the hot and neutral wires are crossed in the outlet somewhere so the current back feeds into your device via printer, external AC powered drive or wired network.
Most of the time you can see a failed Capacitor either discolored or fully burnt.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
djchitown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 24
