주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
MacBook Pro will not boot properly
About two weeks ago a small amount of water was spilled on a friends macbook pro. It has been sitting since then and I decided to see if i can get it running.
When I press the power button (as one normally would when you start a computer) I can hear the HD try to spin for maybe a second or two, the front indicator light comes on, and then the computer shuts down immediately...BUT, when i hold the power button down for about 5 or so seconds, the hard drive will spin up and after the front indicator light blinks at me I can release the power button and it will boot as normal and run like a champ.
I am tech savvy but do not own a mac so please forgive if I don't use apple speak :)
FYI: its out of warranty
I have already performed the following tasks without any luck: reset NVRAM, installed new HD with ghosted image of original HD, taken the battery out to cycle power, tore the MBP completely down to the bones and cleaned the heat sinks and thermal paste (yes i applied new paste).
I am currently working on acquiring an OS disc (Snow Leopard) to try a clean install and see if that helps....
ANY IDEAS???
Cheers,
Wyz
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Try resetting the SMC, here's how: http://support.apple.com/kb/HT3964
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I tried resetting the SMC as suggested. Is there any way to know it has been reset? The light on the power supply never changed or cycled. Anyway, no luck, same situation. It seems very odd to me that if I hold the power button in it starts up...almost like i am overriding a setting or sensor. Also, I ran AHT and got the error: "4sns/1/40000000: IPOR - 9.166" Thanks for the help! Any other ideas?
댓글 달기
I have the same problem. But also cou will not clock higher than 800mhz. Not found a way of fixing it yet though!
Cpu would also use 100% unless in safe mode. But theres a file you can delete to stop kernel using all cpu.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have this same issue as well. Not sure why this was marked answered if it didn't resolve the issue....
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same problem here. solderd an brand new ic i625 still same issue
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 2,723
