주요 콘텐츠로 건너뛰기
The Whirlpool WRS588FIHZ is a side-by-side stainless steel refrigerator with a total capacity of 21.7 cu. ft., featuring frameless glass shelves, LED lighting, adjustable gallon door bins, and a factory-installed ice maker. It is equipped with electronic temperature controls, temperature alarm, automatic defrost, and is ADA compliant.
Why is my ice dispenser intermittent while in use
Ice and water dispensing cuts in and out during use
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @michaelbon86659
What is the full model number of the refrigerator?
Asking as there are 3 models beginning with WRS588FIHZ i.e. WRS588FIHZ00, WRS588FIHZ04 & WRS588FIHZ06 and they're all slightly different.
댓글 달기
답변 1개
Change your water filter inside the fridge the model number is usuallly on the filter itself . If you have hard water the filters should be replaced on a three to 6 month interval . If you connect the water feed from a Reverse Osmosis you can save on filters by using a blank in fridge it acts like a bypass.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michael Bonnecaze 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 19
