주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 Lexus LS 430(UCF30)은 2000년 1월 북미 국제 오토쇼에서 2001년형 모델로 처음 공개되었으며, 새로운 차체 디자인과 다양한 신형 인테리어 및 기술적 기능을 선보였습니다.
Turns over but won't start
Heard a poof sound while driving. Then everything siezed up like a system shutdown, but all electronics were still fully operational. As I turned switch over, car just hesitates but won't fully start. Replaced the fuel pump. Could it be the cam or crankshaft sensors?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@chosey tehre are 100's of reasons why this is happening and what may have haaperend. Since we can't see not hear what your Lexus is doing, we depend on you to de as descriptive as possible. statements like this "As I turned switch over, car just hesitates but won't fully start" need to be clarified. What hesitates? Is it just not turning over fast enough? Or it tries to start but does not run right and dies out again? What have you already checked?
의
댓글 달기
답변 1개
Hi , check your main relay switch in fuse panel under the hood, mine had corrosion built up from moisture over the years and had poor contact and would turn over but not fire up. I had to run 4 wires out bottom of fuse box and clipped a new relay and fired up like normal. Im assuming you have checked for spark and good clean gas is in tank? Also check your spark plugs out make sure they are evenly coloured and gapped . Good luck , it’s not a hard job to replace the relay also check fuse box inside the car .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chosey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 148
