주요 콘텐츠로 건너뛰기
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
Triggers not working (RT Stuck at 100%)
It all started when I opened my controller to repalce the shell. After I assembled it I noticed that my right trigger is fully pressed all the time so I thought naybe I damaged the sensor...
I ordered a new sensor and my friend helped me replace it, but even after that it was stil the same. After opening it again and using a multimeter we noticed that both triggers sensors are not recieving power. We checked that everything is connected and nothing seems off.
What can cause this and what can I do now?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Are you sure the controller is 100% correctly assembled? Nothing in the way?
If yes, please check the motherboard. Nothing damaged on there? Are the traces still fine and not damaged?
Does everything else works? As in wired and in battery mode?
If possible, can you share some pictures with us regarding the triggers and motherboard?
Thanks!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
ItsTyrex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 35
전체 시간: 35
