주요 콘텐츠로 건너뛰기
2021년 9월 24일에 출시된 iPhone 13 미니는 Apple의 iPhone 13의 소형 버전으로, 두 번째 미니 iPhone입니다. 5.4인치 OLED, A15 바이오닉 프로세서, 듀얼 후면 카메라가 탑재되어 있습니다.
WiFi and Bluetooth barely works - why?
9-year-old’s iPhone 13 mini. Had a very unprofessional screen + battery replacement. Now:
  • WiFi disconnects constantly (especially when gaming)
  • Bluetooth range/connection is terrible
  • Screen flickers on home screen
Already tried the usual WiFi resets, forgetting networks, etc. – no change.
Questions:
  1. On the 13 mini, are WiFi and Bluetooth handled by the same chip or antenna flex cable?
  2. Could a botched screen replacement (tons of leftover glue, possibly damaged flexes) cause both WiFi and BT issues?
  3. Any specific things to check inside?
Thanks so much!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Update your phone to it's latest software version can help you in fixing the issue.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @come8cmice30789
Try using the WiFi in the phone as close as possible to your home network router i.e. <15cm and check if it detects, connects and maintains a stable connection.
If it does, mostly likely it is a problem with the antenna - loose connection or faulty.
Here's a previous answer in ifixit that details how to remove/replace the antenna in the phone.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Answer too:
1 I believe so
2 Most likely not, but I suppose it could
3 I would check the antenna connections, and the connections between the board/screen so you can make sure there are no shorts/kinks in the cables.
Try making sure you have nothing close that can cause interference... Hopefully this works
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
come8cMiceTRPr&?hqqy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 20
전체 시간: 20
