주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 9월에 출시된 휴대용 블루투스 스피커인 JBL Flip 6의 수리, 분해 및 문제해결 정보입니다. 이 기기에는 우퍼와 별도의 트위터, 듀얼 JBL 패시브 래디에이터가 탑재되어 있으며, IP67 등급의 방수 기능과 12시간의 배터리 사용 시간을 제공합니다.
Can't enter AUX mode
I've watched several videos and followed online guides trying to access AUX/service mode but when I press and hold the bluetooth and play/pause buttons it doesn't shut down as it should. I have tried with numerous cables and no luck. Is there something wrong with my device or am I doing something wrong?
I am also unable to execute any command involving holding multiple buttons down. I have attempted a factory reset to no avail. It is unclear whether or not I need to contact JBL and have it looked at by a professional.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Peace be upon you.
At first use oil. then
The JBL Flip 6 lacks a traditional 3.5mm AUX input but supports a USB-C "AUX mode" (also called service mode) for wired audio playback from a connected device. Your issue with buttons not responding to multi-press combinations, including factory reset attempts, suggests the speaker may already be stuck in service/lock mode, where buttons are intentionally unresponsive.​​
Correct AUX Mode Steps
Ensure the speaker is powered on first. Press and hold the Bluetooth (rear) and Play/Pause (front) buttons simultaneously for 10-20 seconds until it shuts down and restarts—then connect a USB-C to USB-C or USB-C to Lightning cable from your source device (phone/laptop) for audio. Buttons like volume won't function in this mode; control from the source device.​​
Troubleshooting Button Issues
If multi-button presses fail entirely, the speaker is likely locked: Plug in the USB-C charger (required), then press and hold Bluetooth + Play/Pause for 10-20 seconds to exit service mode. For factory reset afterward, hold Play/Pause + Volume Up (+) for 5-10 seconds until it powers off. Persistent unresponsiveness may indicate hardware faults like button damage, common in repairs or fakes—test single buttons first and consider JBL support if unresolved.​​
When to Contact JBL
Contact JBL support or a service center if resets fail after charging, as this points to potential flex cable/button defects rather than user error. The device, released in 2021, has a typical 1-year warranty, but check your purchase date.​​
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
devans3543@gmail.com 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 120
전체 시간: 917
