주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad E15 Gen 2는 2020년에 출시되었습니다. 11세대 Intel Core i3/i5/i7 프로세서 또는 AMD Ryzen 4000 시리즈 CPU가 탑재될 수 있습니다.
Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
  • Power off the device and carefully clean the port using compressed air or a non-metallic tool (such as a wooden or plastic pick).
  • Inspect the port with a flashlight for visible damage or corrosion.
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adrian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 78
전체 시간: 487
