주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
질문 마감됨
iPhone home button not Working after Replacing
So after reading on the web and here I took the plug and replaced the home button on my wife's iPhone. Now it does not work at all. Did more research and found that replacing the dock connector, that could also be the problem should fix it. Well just did that fix and still the home button does not work.
Any suggestions?
All the parts were purchased on this website so I would think that they would be high quality. The phone has not lost any other function other than the home button.
I do have another home button I could try, but I am seeking others insight before I proceed.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Replaced the home button with a new one and all is good. Should have tried that before replacing the dock connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Ensure that the ribbon cable is not bent or cracked, and is securely connected.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have looked at it a couple of times from the backside and there does not appear to be any cracks, or bends.
Tomorrow I will tear it all back down and check the function of the button with a DMM. I am thinking it's a bad button.
댓글 달기
Did you ever get this resolved? I've replaced the home button assembly and dock connector and still not working. First problem was an occasionally working home button. After button replacement, home button worked a bit and now entirely unresponsive. (using soft home button in accessibility). Replaced dock connector, still same problem. Wondering if you found a solution.
ben
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I had ifixit send me another home button, installed it and it seemed to fix the problem.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,143
