주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
589 질문 전체 보기
Is it possible to replace the non-swappable battery?
I read somewhere that the battery on the new macbook pro (non-retina) is advertised to sustain 1000 charges. After the battery is dead, can I replace the "non-swappable" battery - by myself or via Apple care's services ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Yes, even though Apple puts a label on the battery that says non removable there is only one try-wing screw holding it in place and replacement are relatively easy to find because if has the same battery as the 2011 model. Apple also will replace your battery for (I believe) $200 at the store.
Hope this helps
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Yes, you're right. Also, I add that, of course, when the Macbook is still on warranty, servicing it at home may void the warranty, so, it's a good advice letting the Genius Bat techies do their job.
댓글 달기
귀하의 답변을 추가하세요
desafinado 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,485
