주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
질문 마감됨
Are pentalobe screws still good after removed?
i was replacing the back of my iPhone to make it red, i put the new back in and tried to put back my pentalobe screws but they wouldn't go back, is this supposed to happen, do i need to buy Phillips screws instead??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Yes, just like any other screw, as long as the correct bit is used to remove it, it will go back in just fine. Did you use a proper pentalobe screwdriver, or something else as a stand-in? Our iPhone liberation kit uses a standard star bit to remove the pentalobe screws, which strips them, which is why we then include Phillips screws to replace them.
P2 Pentalobe Screwdriver iPhone 이미지
상품
$5.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I ordered a new backing, it was sent with two screwdriversmid didnt know which was which and i think i used the wrong one
댓글 달기
가장 유용한 답변
Check if the new back cover is seated properly. Screw should go back in provided that its head is not damaged when you removed it. Use the correct screw driver to remove screws.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 2,905
