주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meta Quest 3S 혼합 현실 헤드셋은 2024년 10월 15일에 출시되었으며 Meta Quest 3의 보급형 모델입니다.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
It is possible for headset tracking to stop working due to sensor issues, software glitches, or connectivity issues. Ensure that the play area and lighting are properly set up, restart the device, and check the tracking cameras or sensors.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kai Bannon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 71
전체 시간: 471
