주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
마이크로소프트(Microsoft)에서 설계한 Xbox One S는 2016년 8월에 출시되었습니다. Xbox One S는 Xbox One의 재설계 버전입니다.
Why Isn't My Xbox One S Working?
My Xbox One S Is Giving Me No Signal On My TV. But The Light Won't Turn On Unless I Press The Eject Button, It Will Run For Maybe 5 Or 10 Minutes Without Picture, Then Power Down. Neither The Power Or Sync Buttons Will Work.
Does Anyone Have Any Clue What's Wrong With It? I'm Thinking About Replacing The HDD Drive And Internet Power Source. Also I Don't Have A Brick Power Cable I've Got Just The Basic Plain Cable If That Helps Any.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
does it tell you no signal out when you turn it on?
Could be a lot of things. It will be easier if you upload a video. Is it possible for you to do this? Thanks!
댓글 달기
답변 1개
No signal is usually a strong indicator of a bad HDMI port. While you wouldn’t expect this to affect the system to power on if the Xbox doesn’t detect an output signal it won’t power on. I would check this first. As it’s the cheapest fix but it does require some skill to replace. Other options would be a dead power supply bad capacitors can also cause this is a swappable part.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chrystopher Lyle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 18
전체 시간: 105
