주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1136 / 30, 60 또는 80GB 하드 드라이브 / 검은색 또는 흰색 플라스틱 전면 패널
iPod won't charge
I bought a used Ipod Classic 5 about two months ago. The seller put a new battery in as well. I have been using it fine for about two months now. Charging via wall and/or computer worked fine. I haven't used it for about two weeks now and the last time I used it I did until the battery was completely drained.
I went to charge it on my wall outlet now and it wouldn't show any signs of life.
I waited a good 2 hours and still nothing happened.
Whenever I tried turning it on, it would just show the apple logo for a brief second and then shut off again.
Something weird to note is that after nothing happening via wall charge I tried charging it on my computer and when I plugged it in I got a windows notification for a USB power surge, telling me to immediately remove the device from USB because it was drawing too much power.
What could be happening? And how do I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Replace the battery. The battery the seller replaced it with is probably a low quality cheap one.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It looks like you can get the full Fix Kit from iFixit for $19 USD
의 공유
댓글 달기
Try use Firewire if you can, if it shoots into life, which it should as it gives much more power and it lets iPods with even a basically dead battery to turn on, it is probably the battery that is the issue as it may be a low-quallity one.
iPod 5th Generation (Video) 대체 배터리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pazulay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 24
전체 시간: 145
